Recently replaced my original Prestolite Alternator on my 1973 225 OMC with a one wire.  The voltmeter on the boat never read more than about 11 volts, regardlessof if running or not.  Previos to replacing the alternator, it was evident that the voltage on the boats meter(not perfectly acurate)  would drop over the day.<br /><br />After replacing we could run all day and idle, or just sit with the fish finder, gps in cig lighter, and radio for hours and the bat always read 12 volts.<br /><br />I am under the impression that when you start and run the boat ~2000 rpm you should be reading 13-15 volts at the battery?<br /><br />What could be causing this with a new one wire alternator, but battery still reading 12 volts when checked after running all day?
