rogerwa
- Nov 29, 2000
- 2,339
I got the boat out for the first time this weekend. I noticed it ran real hot when at idle. When I bumped it up to around 1500+ RPMs it would cool down nicely.<br /><br />Is it possible the impeller is bad? Or is this not symtomatic of the LU impeller? I am going to check the T-stat first as this is the easiest, although I just tested it last fall.<br /><br />I read in some of the other posts that this is more likely the engine circulating pump. Although, don't these start to leak or weep before they go bad??<br /><br />Also read that the power steering cooler maybe a clog.<br /><br />I have an 87 3.0l Mercruiser with power steering..<br /><br />Any guidance would be helpful..
