Replacing Gimbal Bearing
Can you replace a Gimbal Bearing without buying all of the expensive specialty tools? If you can do it, what can you use instead?
gspig
Re: Replacing Gimbal Bearing
Tools you will need: Large internal snap ring pliers, slide hammer (unless you want to pull the engine and drive the bearing out from the inside), and a hammer and drift pin. No real specialty tools needed for this job.
hoot
gspig forgot big allen wrench and cheater bar for trim bolts, bellows expander, alignment shaft, shift cable socket, possibly a heat source (torch?), and a BAH (big a** hammer). and also a clamp crimper if replacing the shift bellows. you also need a good cuss word vocabulary and a lot of patience. if you are considering this as a DIY, read some of the post about it and do a Google search on the topic. almost forgot, bellows adhesive required too. if you have a buddy at a boat repair shop, you might borrow some tools, but you will need some items not commonly found at Sears.
gspig
I can remove my gimbal bearing without removing the bell housing. I didn't realize that was necessary. ;)
novicetech
You could get a slide hammer at an autozone if theres one in sharpsburg. but then you would also need an alignment tool and a bearing driver.<br />Call around, we have a place in northern cincinnati that rents those special tools if you are close enough.
