Re: 5 VOLTS AT COIL NO SPARK
it would not matter<br /> with the points closed you should really see no voltage between either post and ground, you may get a small bit thats being dropped by the coil but it will be insignificant. once the points(switch) is closed there is a complete circuit to ground. that means one end is at about the same potential as the other. points open and key on you should see about 12V. the ballast wire wont start resticting current without current flow. the current causes heat witch steps up the resistance. so back to the problem. at 5 volts with the points closed means the contacts on the points have incredibly high resistence. voltage is just potential, does not care much about resistance. current flow on the other hand does care. think of your points as a light switch. you may have 12v when the switch is open but when closed(under a load)no volts. if you have voltage acrossed the switch with the switch closed the switch has excessive resistance. high resistance means reduced current flow, reduced current flow means the primary coil winding magnetic field strentgh is to low to induce a voltage in the secondary windings which leads to no sparks. can also lead to much cursing and tossing of wrenches. a DVM can and will be your best friend,but only if you know what its telling you. think of it this way, your ground lead is connected at the distributor, your looking for a potential difference, wont matter which side of the closed points you set the positive lead on, the potential difference is the same. now go to the -term on the coil. if the wire from the points to the coil is good the potential is the same as at the dist body. now go to the + side of the coil. your now measuering the potential difference of the resistance of the primary windings of the coil. usually its not much resistance so there is not much voltage. open the points and it changes dramatically. a shorted or partially shorted( low resistaance) condenser can create some of the same results. remember the condenser is a large capacitor, it will block DC and pass AC. the rapid rise and fall of the voltage on the points acts like an AC signal. if you check it with a peak reading meter while running you will actually see about 150 volts or so. good luck and do a bit of studying on the primary and secondary coil operation and the muddy waters may clear a bit.
