herbmadill
- Jul 20, 2005
- 2
I have a 1979, 470 mercruiser 170hp. The water pump shaft is worn causing the water to leak past the first seal and out a drip hole. I am told that this shaft is part of the camshaft and I also have seen some parts diagrams that show it to be a separate piece. At any rate there was someone in the forum that mentioned a "speedi sleeve" component that would slip over the worn area and yet would still allow the use of the same seal. Does anyone know where this "speedi sleeve can be purchased?
