I have twin 92' Alpha 2 out drives (one is counter rotation). In 2004 I lost both uppers within 2 running hours of each other. This was after 25 hours run time for the season and a total of appx. 600 hours on the drives. I did the lubrication on the drives so I know they were full at the begining of the season. I did not do a pressure test at the begining of 2004. So after $8k I replaced both drives by a certified merc dealer (both entire units). So at this point I thought I was good for another 7-8 years. There was no determination on exactly what caused the uppers to sieze. No fishing line in the props, no apparent oil leaks. (By the way this boat has no remote monitors and is in the water for the season).<br /><br />Now comes 2005 on the family trip (125nm miles from home dock) and after appx 35 hours of run time on the new drives the counter rotation drive siezes again, and again lack of lubrication on the upper half of the drive, the lower was fine. There was no hint of oil in the bilge, witch would be the sign of a drive shaft leak. Again I personally did the lubrication for the season and tripled checked the levels and put in exactly the amount the manual suggests. I took it to another Merc dealer where I broke down and after another 2.5K he replaced the upper half of the drive and flush the bottom and reused it. He did a pressure test and all looked good. So I drove the boat across the lake appx 130NM and all was fine. The very next trip I took, 6 days later after 5 hours run time, it happens again. I took the top plate off and it was metal soup, the bearings looked intact but the gears were a mess. At the time of failure i was cruising at appx 3400 rpm (same as the second time the counter failed) then the engined raced to 6000 rpm at time of failure. Once again no apparent oil leaks, gaskets good on the fill/vent holes, no oil in the bilge, no oil around the drive housing.<br /><br />Is there anyone out there that has had a similar situation or has any suggestions I would greatly appreciate your input. <br /><br />Thanks in advance. <br /><br />Sincerely,<br />Mad Boater
