merls bait shop
- Apr 22, 2015
- 22
hello, the specs say to dial in timing to 8 degrees btdc , my problem is i can only get to like 12 degrees btdc before it stalls out. also i adjusted carb idle mixture screw 1 1/4 turns out from all the way in and seems to be flooding out, i was thinking about spraying sea foam in there maybe the float is sticking. any help would be appreciated. thank you.
