FreeBeeTony
- May 15, 2002
- 3,991
I know alot of you have been waiting to hear about my progress.<br /><br />Well, picked up the trailer yesterday and hauled the boat out of the water today.<br /><br />Pulled the outdrive hoping to see something like bondo posted. I didn't see an exhaust flapper, but I did see what appeared to be a bolt. All the way in the back looking into the exhaust passage from the transom. I can't see it to well, even with a drop light. The bolt was vertical. I was able to reach it with a couple of long 3/8" extensions. It's not loose, I couldn't move it. From what I have seen looking at figures of the y-pipes, this bolt shouldn't be there. Or is is supposed to be there? <br /><br />How does the y-pipe mount to the transom plate? I thought it was 2 or 3 bolts going into the transom plate. If that's the case I shouldn't be seeing what I am seeing.<br /><br />I removed the rubber boots and elbow between the risers and y-pipe and ran a garden hose through. As my son applied the water, I watched from the outside. The water seemed to come out of the holes on the sides of the gimbal housing, rather than the main exhaust passage.<br /><br />Had to walk away from it for today........
