Re: mercruiser stern drive install?
I am happy you got it back on, and I certainly don't want to rain on your parade, but....<br /><br />If all you did was remove the outdrive to change the water hose, and then had to "add some washers" on the rear engine mount to get it back on, then something is seriously wrong. The rear motor mount is not adjustable. There is a set number and order of parts back there - adding to them will guarantee problems with the alignment and a sure coupler failure. The adjustment is at the front mount.<br /><br />Did you use an alignment tool or simply add washers will it went back on?
<br /><br />I just edited this reply - after rereading your post, I notice you didn't actually say you added washers to the REAR engine mount. Even so, where and why are you adding washers? Is the adjustment nut all rusted up and unable to be adjusted - is that why you had to add washers?
