glassmancanada
- Aug 10, 2015
- 33
Nissan/Tohatsu throttle cam removal/upgrade to 15hp, timing question, w/p questions, dead CDI tip
Hey all, hopefully I can get a few questions answered here.
I have a Nissan NS12C and I have ordered the throttle cam for the 15hp 362-63718-0M. I cannot find any parts manual for this engine but I have gone through the Tohatsu parts manuals and it seems my engine is identical to the M12C2, M9.9B2, M15B2.
Anyhow, I've read through the thread on 9.9 to 15 hp conversion and I have a few questions.
I removed the linkage to the coil plate assy as advised to get the cam bolts out but I cannot get the coil plate to rotate enough, intake casting is in the way. Do I need to remove the flywheel and coil plate? Pics attached
Also could someone verify the timing settings on my engine? I bought it used but I'm having a hard time telling where it's set and what the reference mark is. Pics attached of idle and WOT positions. Do I need to bump the timing to 25 degrees at WOT as some have suggested?
I included pics of my throttle plate position when the cam is fully levered and it appears to be fully opened at 180 degrees to the bore determined by the stop on the carb. Will I still need to adjust the lever once the new cam is in?
Could someone take a look at my w/p liner and guide plate and give their impression of condition? I polished them with crocus cloth but should they be replaced along with the impeller due to step wear?
On an unrelated subject I wanted to offer a tip that I discovered on faulty CDI boxes. Not sure if this is common knowledge but it saved me $260.00 so I wanted to pass it along. When I bought this engine I had a no spark fault and it wouldn't run. Determined it was a dead CDI and found it was $260.00 to replace!! I happened on a youtube vid at the last moment before ordering a new one where the guy was claiming the 75% of them could be saved by baking in the oven at 300 F for 10 minutes. Apparently what happens is the epoxy fill underneath the CDI separates from the casing and moisture gets in. It cannot evaporate as the casing holds the moisture in at the top. By turning it over and putting it on a pie plate in the oven the moisture is cooked out and the CDI works again. I did this and it worked like a charm, sealed up the bottom with shoe goo and also glued around the wire grommet so the moisture cannot get back in.
Regards,
Pics show coil plate position and cam bolt position/interference
Timing at WOT
Timing at idle
Throttle levered full open showing carb tab stop
Throttle levered full open on carb tab stop showing throttle plate at 180 degrees
Throttle plate position @ WOT with stock cam
W/P liner and guide plate pics
Regards,
Timing at WOT
Timing at idle
