Re: Hailing Hystat
Received and installed the ESA along with the Pertronix Ignitor and coil. BTW... they only make the "P" model now and it will work either with points or Pertronix... according to the website.<br /><br />Fired right up, purrs like a kitten! Never even had to touch the timing either.<br /><br />However, did your ESA seem to work in the drive? Mine seems like nothing happens. Checked and will double check the wiring again, but there really isn'y anything to wire wrong. Like you, I had to hack the plug. Overstroke and stumble switches check out. I reset the overstroke adjustment as it was off by the book. <br /><br />Maybe I won't see any difference until I get into the water. Then again,maybe the new module is not working.
