Re: Taking Boat off Trailer For Repair
I would build up some proper wood supports for it. Two supports for the back, and one for the front with a V in it to hold the keel. You crank the trailer jack all the way down, place the rear supports under the transom area, and crank the trailer jack back up. This will place the rear of the boat on the supports, and continued cranking will lift the rear of the boat off of the trailer. To place the front support, you can use a floor jack and a piece of 4x4, place under keel, and jack it up. You should now be able to roll the trailer part way out. The axle and other crossmember will want to hit the jack/wood 4x4, so you'll have to set a support behind those crossmembers/axle so you can remove the jack/4x4. At this point the boat will be supported at the back and probably half way towards the front. Once you have jockeyed the jack/4x4 and the front support to get the trailer out, you should have been able to work that front support towards the front enough to give stable support. I hope I described it good enough.
