I went to my local marina this weekend to check over the boat, do a little wax and clean-up, getting ready for spring. Since it was stored inside all winter, I figured a couple of hours and I'm ready. <br /><br />Instead, I'm horrified and afraid that the boat is ruined or seriously damaged.<br /><br />As I got inside the boat (18 foot Monterey) I thought I would open the ski locker for some ventilation. What I found was water just an inch or two from the top of the locker (and floor), with my fenders squashed against the edge, and with a big chunk of ice underneath!<br /><br />After my shock, I called in the marina owner, who said that "some water in the bottom is no big deal...it's a boat." But he admitted that this was a lot of water, but felt that it likely caused no damage...<br /><br />To make a long painful story shorter, I pulled the drain plug and removed approximately 70-80 gallons of water! The water in the engine area was up to the bottom of the oil pan, but may not have touched the starter or fuel pump.<br /><br />The marina is going to pull the boat out into the sun and let it dry out for a day or two, then they'll check it over. <br /><br />Here are the issues I have:<br />How did it get so MUCH water? My best guess is that the dealer who winterized the boat left it out during some heavy fall thunderstorms without the canvas, and they never drained it or removed the plug at all (and maybe left the engine drain water into the bilge as well.) <br /><br />Or the marina where it was stored left it out (though I saw it with canvas on after it was delivered there). Or some combination of the two. No apparent roof leaks visible in the building where it was stored...<br /><br />What damage was likely done? Assuming that at least the engine was properly winterized (I'm hoping), would water and ice have caused damage? No visible damage to hull or deck, and carpet isn't soggy...<br /><br />What should I look for, and what precautions should I take. If the motor runs fine and boat has no apparent problem, will it still never be "right" again? <br /><br />
I'm figuring that I may have to have an attorney involved, or my insurance company, or a surveyor, or something. I'm sick over this, so any advice would be appreciated. Thanks!
