tallcanadian
- Sep 7, 2006
- 3,250
That's some nice fabrication on the "Flip Brackets"!!!!:sad:
Uhmmm, what were the temps when you applied the primer???![]()
6C Mike is around 43F.
Thanks Sphelps and GM!
At work I use PPG Envirobase, AKA Waterborne basecoat. Its a great system, been spraying it for 10 years.
I could have gotten some actual "flake" like you traditionally see in bass boats or amusement park rides from my rep, but it actually is so large it looks like dirt in the paint unless you bury it with 5 coats of clear. I didn't want to get into all that, so I created the color using the largest flake toner on the mixing bank, along with an additive to make the flake stand up more giving a larger appearance. The blue color is more of a pearl. Those colors look best in the sunlight, they are more of an effect rather than a sparkle.
Ill try to get some outside clearer pics today, hopefully it will be somewhat sunny out.
I may sand and polish the sides a bit, but the bottom is ok the way it is. Its a bass boat, so unfortunately it will eventually touch the odd rock while trolling for bass in coves and shallow areas.
I can't see any of the pictures!
