Re: How cold is cold
Hunt, I bet these guys all have outboards. Turned out my neighbor had an outboard. All the water drains out the bottom if you just tilt the motor down into the run position. If the boat is in the water, all the engine water drains down to water level. If the lake hasnt frozen yet, the outboard wont either. Its us guys with the I?Os that are in trouble. And the volume if water in the block is realtively small, around a couple of gallons, so it is fairly easy of the water to freeze solid, not just surface freeze. Admittedly, the situation is not quite as severe for boats in the water too. Since the hull is actually below water level (up to the static line) part of the hull at least is in the liquid water which is warmer than the air keeping the bottom of the hull above freezing. This tends to help keep temps in a closed engine compartment a little warmer than the air temp until the temp gets into the mid to low 20s. On a trailer though, it a bit riskier. I definately drain mine before the temp gets to 33 or less. I have in the last 16 years made a couple of late night trips out to the boat in the drak when the temp was getting to the 33 level to drain it. After one time I'll never get caught like that again. WAY TOO EXPENSIVE!!!
