4.3 LXGen+ 1997 0k009133
tashasdaddy
good to be back. i'm confused. manual shows 2 application of cooling system. 1/ single hose to bottom of manifold. 2/ hose to manifold and hose to elbow/riser. i am seawater cooled. changing from bat wings to 2 piece. what's the difference in these applications, and witch should i do.
Haut Medoc
Re: 4.3 LXGen+ 1997 0k009133
I'm guessing here, but........I would think for raw water cooled system that you would only need the single hose......Unless you have some sort of restrictor plate between the riser/manifold.....What does the flow chart show? That should show what you need to do.....I think you would just need the one though......JK
Don S
If you have a thermostat housing that only has 4 hose connections on it, you can only go to the bottom of the manifold. Note the gasket is a restrtictor gasket. See page 6A3 of the Merc service manual.
tashasdaddy
thanks, before i have to do it twice.
