Gentlemen,<br />I have a 99 Maxum 181ci, 3.0L Mercury I/O. The timing instructions in my manual says to jump the 2 white leads on my EST distributor before checking the timing. Upon jumping and bypassing the shift interupt switch the timing should be 2 degrees ATDC. Then when the jumper is removed the timing should be 13-17 degrees BTDC.<br />My timing read 14 BTDC with and without the jumpers. Has anyone experienced this issue? Or does anyone have a solutions? The engine runs OK, just wanted to do some winterizing and checking.<br />Thanks in advance,<br />Marty
