Re: OMC lower unit install procedure - Driveshaft
Orginally, OMC discovered that there was no clearence for the u-joint coupler to slide past the bellows. Compounded by cold weather where the bellows was stiffer and well..... it could be a B*#*ch to get past the initial opening... OMC then made the specs. .030" larger to account for the problems and most of those units are ezier to get on. Short of replacing the bellows, I'd suggest using a warm hair dryer to make the bellows softer, spray a light oil on the u-joint coupler, install the prop, put it in gear (the O.D. and the control box) and turn the prop so that water-pump impellor rotates correctly and with steady pressure (usually your chest) it should go on, Alignment really is a different concedrn and SHOULD be checked.
