Hello everyone I'm new to this and to boating but I was hoping someone might be able to help me out. A quick run down of problems I'm having are.... I bought boat 2 weeks ago it ran good during test drive and good for about 2 hrs after I got it home. The boat was running fine then sputtered once and moments later died. It showed a little less then 1/8 tank of gas so I figured it had run out of gas. Was able to get a friend to bring about 4 gallons out to me about 2 hrs after being stranded. The boat was very hard to start and wanted to keep stalling out. Finally got it running and hauled back to dock. On that trip back motor was sputtering and when rpm's dropped I'd get a single beep alarm. Brought boat home drained tank pulled pick up tube it was clean. Checked anti siphon valve it wasn't clogged and seemed to operate fine. Changed all plugs, charged batteries. The boat still won't start, it will crank but won't run. I've looked at previous posts about fuel pump and fuel pressure regulator so I checked to make sure I can hear pump turn on for 2 seconds when turning key on. It sounds like it is. I pulled fuel pressure regulator off it appeared clean. I am completely at a loss right now as what else it could be.... Any help would be greatly appreciated
Thanks Matt
One other thing... I get 3 beeps now when I turn key on.
Thanks Matt
