Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
At high speed temperature gage goes to red<br />slow down to half speed and temperature goes to normal. idle is also normal<br /> This raw water cooled Merc.
Is this a raw water cooling or closed cooling system. Merc, Volvo, or OMC?<br /><br />Most likely,,,water pump impeller failure, t-stat failure, or restriction in cooling system
The raw water impeller is the first thing you look at on ANY overheat problem on any make.<br />Usually they are expected to last forever, but in reallity should be replaced every couple of years.
