Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
It MUST ABSOLUTELY be a marine alternator. DO NOT try to replace it with an automotive type. Marine alternators (and other marine parts) are designed to reduce spark, which automotive parts are not.<br /><br />In any case, Overton's should have a replacement. Look for some part numbers and/or amp rating on the old one.
62-65 amp in most cases you can use up to 70 amp<br />that will bolt up if you have a nando( ??) you can replace it with a delco but the main thing <br />it must be for MARINE USE !
here's where I bought mine a couple years ago,<br />haven't had any problems with it although you may want to paint the outside of it when you get it otherwise it'll look like crap after 1 season.<br /><br />I have a model 233 merc with the 351.<br /><br /> delco 10si 2 inch foot
