f_inscreenname
- Aug 23, 2001
- 2,591
Got a issue. My manifolds use pencil zincs. When I was draining the motor for the winter I pulled the two brass plugs ( the zincs screw into the plug) on the manifolds and one came out pretty much intact. The other was gone. It must have unscrewed itself and is now inside the manifold. I have had the motor running a couple times today and there is no restrictions. I have tried to reach up in there with forceps but can not find it (the boat hasnt moved either since I found it missing) . The manifolds are harder then the worst set of headers you have ever dealt with taking them off and on. What should I do?
