Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Tryint to remove-replace 5.7 l, It looks to me like it would be a lot easeir to premount the y pipe to the transom plate, then drop motor in--is this common practice? thanks for putting up with me guys<br />hud
the Y pipe is already mounted to the transon plate.need to pull the drive, remove exaust clamps,rear mounting bolts, front mounts, cables,wiring ,install lift chain and pull up and out.once reinstalled ,check alignment and install drive
yeah ive got it down to a science probably could do it without even takin the drive out!!! small blocks big blocks .. i take about 40 minswith wrenches and wratchets!!
