bruceb58
- Mar 5, 2006
- 30,620
Re: Cruised for 15 minutes. Then Towed back.
If I am reading your previous posts correctly, I don't recall you ever trying to start your engine while you have the oil pressure sensor bypassed. <br /><br />When you bypass the switch, you say your pump turns on, right? If so, try starting the engine at that point.<br /><br />If it starts, it either means you oil pressure switch is bad or your engine is not developing oil pressure. That is why I want you to monitor your oil pressure guage to make sure the pressure comes up.Originally posted by milkyway:<br /> I did not crank the engine on test #5. I have done this many times and it just kept dying. I was just on the RUN position of the key ignition.
