Need some help here, Merc 1993 4.3LX with full closed system. When I winterized it I fogged the carb & cylinders. Over winter I replaced the exhaust manifolds & risers & replaced intake manifold. Was going to change the oil before taking it out today to get the fogging oil out from winterizing it. She started up fine, kept it on the water muffs for 15 minutes to heat the oil up, throttled her up and down with no problems, then shut her down. When I drained the oil it wasnt that thick, pretty thin. It had a light brown tint, not white (milkshake). All parts are new (mani's & riser's). What could this be ???? Thank You!!
