newfiez
- Sep 26, 2008
- 324
Hey guys,
Issue:
I have a customer complaint that the engine was running for about 15 min, then stalled, and could not restart. I found the ground wire loose on the battery, and corroded green. Re-tightened, and the boat started. Ran it for an hour without stalling. Issue I have now is the coil is getting very hot. I also have the purple/red wire going to the + side of the coil getting very hot. Attached to the same wire is a purple/black wire (going to the + on the coil). The purple/black goes to the R on the starter solenoid. The purple/red goes to the alternator, where it's joined (by a crimp) to two wires coming out of the alternator (red/purple and purple), and 2 wires (each are purple) going back into the harness. (SELOC OMC manual 3404, page 10-61, FIG 150 shows this routing is correct).
I swapped out the coil with a 1.5 ohm flame thrower, and had the same issues. The coil that was originally in the boat measures 1.6 ohms
Tests:
Coil + wires purple/black and purple/red disconnected from coil, there's 2.850 ohms at that connection with key off (and battery off). With key on, there's 40.2 ohms.
Coil + wires purple/black and purple/red disconnected from coil, there's 12.4v at that connection key on.
Coil + wires purple/black and purple/red connected, there's 5v key on.
Coil + wires purple/black and purple/red connected, engine running at idle, there's 8.65v (and the tach is wonky), system volts at battery 15.8v
Coil + wires purple/black and purple/red connected, engine running at 2000 rpm, there's 9.24v, system volts at battery 15v
Solution:
Where do I go from here?? I don't see a ballast resistor installed, and it seems like a factory harness. Any help would be great! I'm guessing the purple/red wire from the coil + to the alternator connection is a resistance wire, and it's gone bad and/or the regulator in the alternator is bad.
Thanks,
Jimmy
Issue:
Tests:
Solution:
Thanks,
Jimmy
