As some of you know, I´m in the process of rigging a 17' runabout. I started spring 1 1/2 year ago, but had to take a "little" break rebuilding my house. Now to the subject. This boat is new, was never in water. I do not know where it was moulded nor by whom. <br />Last night I was going to turn it upsidedown to add supports under the cloused bow. ( I earlier added 7 bulkheads in bottum ) I discovered two persons could actually lift the hull from ground. I know I can lift 200 Lbs in that height, and my B.I.L. is somewhat like. This was all I could manage.<br />From my drilling, working etc I´v seen glassfiber is like only 1/4" thick on most of the boat, Except from parts of bottum - 5/16" and transom - MUCH thicker. Floor is glassfiber too with a kind of core material, the upper shell goes all the way down and rests, screwed to bulkheads, kind of a boat in a boat, of coarse a much lighter construction than usual wooden floor. Transom only has wood in the middle like an i/o.<br /><br />My question is: How thick are normal boats ?? How much does a naked hull usually weigh ?? It is 6 1/2' beam at mid of hull,and 17' long. It will be powered by my 115HP Evin. Will a boat that light be strong enough ?
