Re: The Weight of things
Balance was an issue with my rig because not only did I get rid of saturated nasty waterlogged structure, I also got rid of the heavy windshield, a lot of heavy fiberglass up front, and the back to back seats. I was moving weight aft by converting to a center console, so I deliberatly built the console on the heavy side to try to push weight forward, and later adding a casting deck, battery, bow mount trolling motor further helped to achieve a balanced running attitude while at cruising speed. Initially, with just me, and not as much weight up front it did not run well unless I had a person sitting up front. Now it is fine. Yeah, trim tabs would fix it too, but I have more fun with the casting deck/seat/motor combo. Of course, I shifted some weight aft again by adding a 5.5 kicker, and bumping my fuel tank, which rides against the transom, to 19 gallons. It added weight, but it also helps to balance the weight of the kicker.
