It drops the voltage at the coil positive by a principle known as voltage dividing. When you have 2 resistances in series, between a positive voltage and ground, the voltage at the junction of those 2 resistors will be a proportion of their resistances.
For example, if you have 2 equal resistances between 12 volts and ground, the centre point will be 6 volts. With our coil example, if the coil is 1.5 ohms and the resistance wire is 1 ohm, the point where they join, the coil +, will be 7.2v. (1.5/2.5*12v).
We also have Ohm's law to consider. With a total resistance of 2.5 ohms, a maximum current of 4.8 amps can flow. But as a coil is an inductor, the current will take time to reach maximum.
The module senses the current flowing, and a coil is usually fully charged at about 4amps. The module will try to set up the 'on' time until it sees 4 amps flowing before it fires the spark. If you add resistors, then the maximum current will never reach 4 amps.. (anything over 3 ohms resistance in a 12 volt circuit will have less than 4 amps flowing)...This is why adding ballast resistors will make it worse.
Hope this helps...
Chris......
FWIW. I ran a pertronix with an internally ballisted flamethrower coil on a 120 for 5-6 years before I sold the boat. It was still on the water last time I saw it a couple years ago. I would run 25 miles in 100+ temps and never had an issue with overheating the coil. I taped up the resistance wire and ran a new full 12v line in the wire loom alongside it to the coil.
Thanks Thumpar. And did the engine have the original wiring schematic set up, with the original alternator, or a self regulating alternator?
Are you sure it is the coil overheating and causing no spark? Have you checked for spark when it won't start? Could be vapor lock or vent issues.
Thanks again Chris. Okay, so if the purple wire, that is supposed to be a resistance wire, is giving out 10.8-11.6 V, it would need a ballast resistor before the coil, no? It needs to be down to 7V does it not? Somehow the resistance is not there, which is why I changed to an internally resisted 3ohm flamethrower coil, that still gets too hot. A sister boat has a similar set up, with the old original alternator and a Mallory distribution (full piece, EI). He has the purple resistance wire on the + side of the coil and the same flamethrower 3ohm coil that I have. He has 6.3V on the positive and 4.2V on the negative side of the coil and it runs great.
Thanks Thumpar, but all checked. Definitely coil. It starts and runs perfect, until 48-55minutes, especially when ambient temp is high, then rpms drop and it dies. Wait 5 minutes and get 10 minutes of run time, till it stops again. Wait five minutes and so on and so on........
What type of coil can I use with the Ignitor? How do I check my coil's resistance? (12V negative ground only)
To determine if your systems coil is compatible with the Ignitor, some measurements should be taken prior to installation of the Ignitor. Caution… While performing this test, never leave the ignition switch on for more than 30 seconds at a time.
Set your voltmeter to a 15 or 20-volt scale. Attach an 18 or 20 AWG jumper wire from the negative coil terminal to an engine ground. Attach positive (red) lead of your voltmeter to the positive side of the coil, and the negative (black) lead to an engine ground. Turn the ignition switch to the run position. Now read the voltage at the positive coil terminal. Turn the ignition switch off. If the voltage measured is approximately 12 volts, no resistance wire is present. A typical resistance wire will provide 9 - 6 volts.
The next step is to determine the resistance in the primary ignition. Label the wires attached to the coil terminals and note their appropriate location. Make sure that the ignition switch is off and disconnect all wires from the coil. Adjust your meter to the lowest ohm scale. If you are using an analog style meter make sure to zero the needle.
Measure from the negative terminal to the positive terminal. Write your measurement down.
Now the maximum system amperage can be determined. Divide your voltage measurement by your coil resistance measurement. This will give you the system current or amperage.
Four and six cylinder engines should not exceed 4 amps. Eight cylinder engines should not exceed 8 amps. If the total amperage in your system is higher than the amount recommended for your application, you should install a ballast resistor.
Example:
Voltage 12
Resistance 1.5
12 / 1.5 = 8
Total amperage is 8
NOTE: REMOVE OR BYPASS EXTERNAL BALLAST RESISTOR OR RESISTANCE WIRE WHEN INSTALLING THE RECOMMENDED FLAME-THROWER COIL, UNLESS THE PRIMARY RESISTANCE IS LOWER THAN SPECIFIED OR IF YOU ARE USING THE STOCK COIL.
1. To remove a ballast resistor (normally white ceramic blocks 3 to 4 inches long), disconnect all wires on both ends of the ballast resistor. Remove the resistor from the vehicle and splice the wires together at a single point.
2. The resistance wire is located between the ignition switch and the firewall on most applications.
• Locate the resistance wire, cut it out, and replace with a 12-gauge copper stranded wire OR:,
• Bypass resistance wire, connect a 12-gauge copper stranded wire from a 12-volt switched ignition source to the positive (+) terminal of the coil.
Instructions on how to do Power and Ground Tests, and Voltage Tests
Hope this helps...
Chris......
Hey Chris. If I put the stock coil, which requires external resistance, back on and remove the current 3ohm Flamethrower coil, can I put a ballast resistor on the purple wire, before the coil?
