I have a 1991 (or is it 1992?) Johnson 90HP outboard - model J90TLAIE. I had the engine rebuilt about 10 years ago and haven't replaced the impeller since that time. We don't use the boat much anymore. I'd guess it has less than 200 hours on it since it was rebuilt 10 years ago. Maybe less than 100.
The last time we were out, the alarm came on steady. I let it sit for a while and started it up with no further trouble on the way back to the boat landing. Since it's been so long, I thought I'd be wise to put in a water pump kit.
I watched some videos online how to get the shift shaft disconnected, and they were all different from my motor (they said to take a bolt out holding it together - mine doesn't have a bolt). I had to remove a pin and push the shift rod assembly, where the cable mounts to it to the port side and then the lower unit released very easily. I hope I can put it back together properly and easily.
I took some pictures and think the pump, housing and plate look like they're in good shape, which makes me wonder if I have a different problem that caused the over-temp. Though, I was going through some heavy weeds slowly for a while about 10 min before the alarm sounded (but did lift the motor to make sure there were no weeds wrapped around the prop or covering the water intake).
Should I inspect any other areas before putting in the water pump kit and putting it back together? I'm not sure what or how to check for obstructions, etc.
