Bought boat.
robpoe
Well, after digging out the transom of my 1968 Mark Twain, and deciding it wasn't worth stringers, tramson, floor, just to be an old boat that's unremarkable, I bought another boat.<br /><br />I have a good Mercury 650 (65 hp) outboard, and it's a 16foot runabout. The transom seemed solid when I looked at it. <br /><br />Brought it home, and as I was digging out the RTV blue used to seal numerous holes drilled in the transom (looks like there were about 3 different motors on the boat), I found some damp wood in places on the transom. I hung my motor on it, to see if I was going to have flex problems, and the transom is solid. As is the floor. <br /><br />However the boat was (probably) left outside and everything is wet. Well, I kinda take that back. The seats are dry - even though the vinyl on them is shot, the foam is dry. Some of them will need new wood undersides.<br /><br />So here I am with a (much) newer boat, with a damp transom. So how do I best dry it out. I've used the search button, and it seems like I need to drill more(!?!?) holes in it, and use a heat lamp to warm the water out of it.<br /><br />Where? In the garage? That would mean my motorcycle(s) would have to live outside. In my driveway with a tarp over it? It's still winter here, will that affect me adversely?<br /><br />Seriously, this boat needs to last me this summer and next summer. At that point I should be in a position where I can scrap it (if need be) and get another (new??) boat. Do I just say "screw it" not worry about it, plug the holes properly (and install new drains in the splashwell, and the bilge) and run it?<br /><br />Does anyone want a 1968 Mark Twain that's gutted and ready for stringers, transom and flooring?<br /><br />Do I just say screw it, and forget ever boating?<br /><br />Thanks, in advance.
Laddies
Banned
Re: Bought boat.
Rob I can understand your flustration, but I am afraid that a heat gun will only drive the water up the transom and if it's not above freezing there it won't dry out, I don't know if this will work for you or not but for emergency repairs on our race bouts we will wash them with alcohol or acetone---Bob--an after thought may be a shop vac
AMD Rules
Re: Bought boat.
....wash them with alcohol or acetone---Bob--an after thought may be a shop vac
Just be careful not to do those two different methods in that sequence. I know laddie did not mean to imply that, but if you were to try and vacuum out a flammable liquid, the wet transom could be the least of your worries as you ponder what to do from your hospital bed. Safety first. Flammable liquids and vacuum cleaners do not co-operate. Ka-boom.<br /><br />Good luck!
robpoe
Re: Bought boat.
so, what? Use a vacuum in holes in the transom to suck the wetness out??
Tinkerer
Re: Bought boat.
Originally posted by Rob Poe:<br /> <br /><br />So here I am with a (much) newer boat, with a damp transom. So how do I best dry it out. I've used the search button, and it seems like I need to drill more(!?!?) holes in it, and use a heat lamp to warm the water out of it.<br />
Damp and rot aren't the same thing, although one leads to the other.<br /><br />It's possible that a damp transom might even be stronger than a dried out one full of rot.<br /><br />If you want it only for a couple of seasons why bother replacing the transom. You'll lose at least the first season doing it.<br /><br />Why not take it to a professional boat repairer and ask if it's got a few safe seasons left in it, as is? If so, do nothing and get your use out of it. If not, work out if it's worth the trouble and expense to fix it to see if it's worth fixing.
