Woodonglass
- Dec 29, 2009
- 25,930
If I was doing your transom I'd build it using 1/4" ext. grade plywood and laminate l pieces together to get to 1 1/2". If you make transom clamps like these...
and clamp each layer one at a time, it will conform to the curve and be strong as heck. I'd use TiteBond III wood glue and clamp each lamination for and hour before doing the next layer. In one day you're tansom will be done and match the curve perfectly. NOTE" first layer should be glued to the outer skin with Peanut Butter. All the rest you use TB III. Make the transom about 1/2" short all the way around so after it's all done you can fill the GAPS with Peanut butter and form a cove for the fabric application. Hope this makes sense. If not PM me your contact info and I'll call you and talk you thru the process
this is another option as well and use 3/8 or 1/2" plywood,,,
https://forums.iboats.com/forum/boa...ons-on-curved-transom?p=10490831#post10490831
