Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I am in the process of replacing the carpet in an aluminum boat and need some help.<br /><br />As you will be able to tell I am looking for the easy way out!! Is there anything that will dissolve carpet glue from an aluminum boat surface.
I have also used the stiff wire brush and angle grinder works well. After your done you can then wash down with water and clean up the dust. After you have everything clean you can trowel on your glue and then lay your carpet.
That is the easy way. <br />Just be sure to use a good dust mask, eye goggles, a long sleeve shirt, pants, and gloves. those wires can and will embed in your fingers. I know.
