Excess bolt holes
delta247
I have a few too many bolt holes and would like to fill them and repair the gelcoat over them. What is the best way to go about this?<br />Thanks!
Yacht Dr.
Re: Excess bolt holes
Where are the holes at ? below or over waterline ?<br /><br />YD.
delta247
Most are above the water line from fish finders, homemade windows, cup holders, ect, there are a few from rivets that held the boat emblem on. I also have a small gouge below waterline I would like to repair, the right way. Thank you for your help!
Realgun
Baically you clean the hole up first. Usually you make it bigger by dishing it out a bit. If the hole was 1/4" you wqill want the bottom to be 3/8" and the top about 3/4" The you will want a good fiberglass epoxy mix. use cabosil and some glass fibers about 1/8". Mix this up about 4 oz of epoxy 4 oz of cabosil and as much fiber about 4 oz to make a real stiff mix. You want the stick to stand in it and not run off. Put this in the hole and level it off. then you will want to put your gelcoat on after a day or so as long as the epoxy is hard. If you have a gash I suggest if you can get to the backside you layer some glass over the hole the in the hole on the outside to give extra support.<br />There are other methods too!
delta247
Ok, can I use polyester resin? I have some already. The gouge on the hull is not a hole! it is through the gelcoat and slight damage too glass. Can I just fill it the same way as the bolt holes and repair the gel coat? Thanks for your help!
Yacht Dr.
You can use poly resin<br />You can repair the gouge the same way ( without the drill holes ;) )<br /><br />YD
delta247
Ok, time to go to work! Thank you! I will post some pics of the fininshed repair. Thanks again!
Realgun
So little your correct however we already have epoxy or poly so why not that? And actually I have a box of that but need 55 degrees for a day to work makes me mad!
