AMD Rules
- Sep 23, 2004
- 1,707
16ft Munro Fiberglass runabout. Making some progress on the floor & hull re-work: <br /><br />When I removed a section of the floor, I found rot as expected. What I am curious about is the gap between the stringers and the hull. It seems the stringers don't actually touch the hull at mid-span, instead they are supported by 'legs' made of fiberglass. I'll assume this was done to minimize the moisture contact with the bare wood. Was this a common manufacturing practice?<br /><br />Rotton cross member<br /><br />The stringers are not fully encapsulated in resin/fiberglass. There is a sequence of 6" fiberglass strips draped over the stringers, which then get expoxied to the hull and behave as 'legs'.<br /><br />Stringer support 'legs'<br /><br />When I replace this floor, should I use stringers made from resin soaked 3/4" marine ply standing on edge instead of dimensional lumber?<br /><br />For more photos, check out the link in my sig.<br /><br />I'm not sure what is the best approach to take from this point. I'd like to have a solid floor & transom, without spending all of my life's savings. I have removed the top deck already.
