richleroux
- Aug 2, 2019
- 7
hello all, I have a 1974 Johnson 115 and have been chasing a problem I cant figure out, first I should say that this motor has not been run in 10 years but it was due to the same problem I am encountering that it sat so long, so the engine starts fairly easily idles well and runs great for 5 to 15 mins after putting in the water then suddenly dies, it will restart a few more times but the problem returns at a faster rate until finally it will not restart at all till I let it sit for many hours. after having this problem the first time I took the boat home let it sit for a couple days. after some examination I found the electric choke solenoid was choking the motor all the time so I fixed that issue ran the engine at the house for almost an hour at varying speeds and no problem was sure I had fixed it. took it to the lake again today and after a little trouble getting it started it ran awesome for about 30 mins then the same reoccurring problem returned. I have been an auto and diesel tech for a lot of years but this is my first attempt at anything marine and I don't know much about them. im leaning toward the ignition module as ive seen many of them on vehicles do this same thing but it also seems like it could be a fuel problem as a few times after dying I turned the key and it wouldn't even crank like the cylinders were severly flooded, maybe more than one problem? I also am unsure of how the fuel delivery works is there an actual fuel pump? any help would be appreciated
