Hi all...one for the guys that know more than I on the matter...
Although I had strongly suspected that the mpi small blocks were able to adjust timing and fuelling to adapt to different octane ratings in fuel, only today I read that they actually do.
I had wondered this because occasionally I go between regular 95 and 97/98 and even sometimes 99 fuel. Just depending on where I get it and time of year.
although I’m well aware there is no need for it and these things are designed to run on even lower grades than I have at the pumps here, I tend to run some higher fuel through it just before winter storage and sometimes through the season. Without doubt it runs smoother with the good stuff, but anyway that’s another topic.
what I would like to know is how long it takes for the ecu to adjust to a higher or lower rating of fuel (all things being considered and for talking sake if they were never mixed, which most times they are). So if I had 50l of 95 in the tank then completely ran it dry...then put 50l of 99 in it. Would the ecu adjust instantly to the fuel ? Or would it take a while ? If so, what determines such a thing ?
As mentioned, I’m aware it’s not required and probably not something that we need to discuss in those terms, but would just like to know the workings of it.
Thanks
Thanks
