kdiddle
- Mar 22, 2018
- 147
Throwing this out here - as I'm at my wits end as to what's going on.
Background - my fuel gauge on my 16yr old boat didn't work on our first outing this year. In order to test my gauge, I grounded the pink wire which pegged my fuel gauge. I understood that to mean that I had a faulty sending unit. I ordered an identical replacement, and after hooking it up - it doesn't work either.
Of course - I only thought to test the resistance AFTER having it installed, but I got the following reading on the sending unit which, according to the manufacturer, is an accurate ohm reading for approx 3/4 tank (which is accurate). However, my gauge is still not working, but will peg out when I ground the pink wire. Apparently .068 must represent 68ohms here...
How is it that I'm getting movement from my gauge when I ground, but not when hooked up to the sending unit?
