Mark42
- Oct 8, 2003
- 9,334
Found a website where a 33 foot sailboat was built by using urethane foam pannels glued together over a simple wood frame, then covered with a 1/4" of 'glass resin on both sides. The wood frame is only used as a "male mold" form the urethane pannels over. After glassing the outside, the mold is removed and the inside is glassed over too. <br /><br /><br />
<br /><br />The foam is about 4 inches thick and a 15" by 58" piece with glass supports up to 1700lbs before it buckled. <br /><br />Check out this site and let me know what you think. <br /><br /> magallanesboatbuilding
