JasonJ
- Aug 20, 2001
- 4,163
I got that 64 'rude 9.5 horse running good and re-painted it. It was in sad cosmetic shape. For some unknown reason, someone had covered the entire shroud in a 1/8th inch skim of bondo and painted it with house paint. It was cracked, and looked really bad. I took a hammer to it and knocked all the bondo off. The original paint was still there, but otherwise there was no reason to bondo it, the shroud was in fine shape. I decided to update the look a bit, because this generation of motors have a fairly modern look to them. <br /><br />I went with a dark charcoal gray that was an OEM OMC color, and ordered a set of current decals. I think it turned out pretty nice. My end result is a motor that is almost twice a powerful as my 5.5 horse 57, it is the same weight, and has a good look to it.<br /><br />My goal now is to register the boat Monday morning, and go out and do some fishing. It will be a shakedown run for the planerboard mast I built last fal, the planerboard set I built as well as this new/old kicker...<br /><br />
<br /><br />
