chris.olson
- Mar 15, 2009
- 173
There comes a time when something, no matter how good it once was, has to be retired when service parts are hard to get. That's the point I finally reached with my old 1985 Chrysler Force 50.
I had converted the breaker plate to a pair of Ford points that work in it - it's almost impossible to find points for these things anymore. However, it still has the problem of drawing considerable power from the battery for the ignition when trolling at dead idle. The alternator doesn't put out enough power at idle to keep the battery charged.
So......figured I could live with that. But I can't live with the water pump impellers getting ate up every 25 hours due to the water pump housing being scored and badly corroded. A new water pump housing is $230 (if you can find one). But we were on Lake Superior in fairly heavy seas a couple weeks ago when the water pump went (brand new impeller with only 25 hours on it). Was forced to run the engine anyway to get back into port and overheated the top cylinder. Did a compression check on it after we got it out of the water, 75 psi on the top jug. Not worth sticking any more money in it.
So I happened to come across a complete replacement assembly - a 60hp Merc inline-four that did not run on the top two cylinders because it had a bad reed block. But at least service parts are available for the Mercury without the required searching thru junkyards to keep the old Chrysler Force running. Split the cases on the Merc, replaced the broken reed block, inspected the rest of the internals (looks like new yet), new paint, fired it up and runs perfectly smooth like Merc inline-fours were born to run. Ran it on the old International hydraulic dyno (made in the 70's in Minneapolis, MN), and while not totally sure of the dyno calibration, it made 63 hp and 58 lb-ft torque at 5,750 rpm.
Finally had to give up on the old Chrysler.
