FreeBeeTony
- May 15, 2002
- 3,995
I have noticed what I believe is a slow leak. I keep the boat ('78 20' Grady White Gulfstream I/O) in the water at the local docks. I only use it on w/e but usually check on the boat a few times during the week. When I go down to the boat, I open the engine compartment cover and usually find a little water in the bilge, not even enough to turn on the pump with the float switch. I pump out what the pump will and leave. I don't think it's the bellows, they looked fine before I dropped the boat into the water. I just bought the boat last year, this is the first year I am leaving it in the water, last year I trailered. Is this little bit of water something I should worry about?
