Greetings, So I have a Mercury 150hp Black Max that starts great and Idol's great, but any thing over about 1/4 throttle and it starts surging and will not go over 3100 rpm, even in neutral.
So far I have replaced all electronics, Stater, trigger, switch boxes, all wires, Plugs, coils, Control Box And cables, Thermostats, Completely rebuilt all 3 carburetors, Rebuilt fuel pump and poppet valve.
Engine is running 125 PSI compression +/- 2 on each cylinder.
It doesn't seem to matter if the engine is under a load or sitting idle it still seems to do the same thing.
This is a "new to me" project So I am unsure where to even start.
When I picked it up I was told the engine had set for about 20 or 30 years If not longer Naturally everything on the outside of the engine was deteriorated very badly and had to be replaced.
Any help is greatly appreciated.
