How to wire switch so I can charge 2nd battery from engine?
tony_cliffy
I have a dedicated starter battery and a dedicated deep cycle battery and have no switch between them - electrically separate withno shared grounds or anything. They each power separate fuse blocks. I often fish all night and would like to charge the deep cycle, if possible, using the alternator output. I have two questions:<br /><br />1) How long would I need to run the engine to get an incremental charge? I'm not expecting a full recharge - just every little bit helps.<br /><br />2) How to wire? I have a Perko switch - just not sure what wire(s) come off the engine. I will need to run both a positive and negative to the deep cycle and think (might be wrong here) that the starting battery only has a single wire running to it from the alternator output. The engine is a 2004 Johnson 4-stroke 115HP.<br /><br />Thanks!!!
Boatin Bob
Re: How to wire switch so I can charge 2nd battery from engine?
tony...you need a jumper cable to join the 2 batteries together at the negative post and then take the wire from the motor and put that on the C (common) post of the switch and then a wire from pos 1 to the start battery and a wire from pos 2 to the deep cycle (or visa versa). NOTE: some switches are ok for switching while running they "make before break", you can go from 1 to both to 2 but never to off. Make sure your switch says you can do this or meter it to make sure otherwise you make fry your alt/reg.
tony_cliffy
Good point about frying the alt - I now remember that being mentioned before.<br /><br />Any potential issues with joining the 2 batteries at the negative post?
gsbodine
no. it sounds like you want a setup similar to what I have. Perko switch and two batteries. Just do like Bob said and you should be fine.<br /><br />This may be of interest to you:<br /> http://www.perko.com/diagram2.html
tony_cliffy
Will recharging your deep cycle battery during a 20 minute run make much difference?
gsbodine
In my experience, no.
tony_cliffy
How long? Again, just looking for a little extra juice in case I'm doing an all night fish trip or something. Getting 10-20% back would help.
gsbodine
Well, I really don't know, but I guess if you're only looking for 10-20%, I would say maybe. I have no idea how much juice your alternator is spitting out, but I figure it's prolly more than my 25 year old one. I mean, it can't hurt to wire up the switch I wouldn't think, and it only costs about $20-25 plus wires. <br /><br />I also know that there are optimum RPMs to cruise at to achieve the best alt output, but I don't remember what they are. If we're lucky 18rabbit or ThomWV maybe will chime in. Or you could use the search feature above and read through some old posts. I remember reading it here somewhere.<br /><br />OK, edit: <br />Here's a thread that will interest you somewhat; pay close attention to Thom's responses, as they are always very detailed and excellent:<br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=27;t=001002#000002
Boatist
Tony<br />Yes a charging deep cycle for 20 minutes can make a big difference. Deep cycle charge a lot like a regular starting battery. To start will draw a lot of amps and as it charges up will drop down to lower amps. I am not sure of the output of your alternator but many of the later model alternators put out 30 amps or more.<br /><br />My alternator is 35 amps on my I/O and it charges my starting and deep cycle battery just fine after a long day drifting or a night at anchor. I charge my batteries thru a battery isolator so there is no risk to the alternator. I do not have a trolling motor so my deep cycle just runs runs most of the electronics and extra light at night.<br /><br />To hook up a isolator just take your alternator output wire and run to the input wire on the isolator. Hook output 1 to your starting battery and output 2 to your deep cycle. Now anytime the motor is running you will charge both batteries. This will extend the life of your deep cycle battery. It will also make sure that your discharged deep cycle battery will not draw current from your starting battery.
ThomWV
I don't like isolators, some people do, some people don't. Don't get the idea that they have no drawbacks, they do. For instance all isolators draw off some power even when the boat is not in use. Find out about them for yourself and decide if your use demands one or not. I'm not here to start an argument as to if they make sense or not.<br /><br />I beleive your alternator has about a 25 amp output. It will not attain this level of power production until the engine hits somewhere around 1,500 RPM but after that it will maintain its maximum output at any higher RPM. So that 25 amps (or whatever the number is (look it up in your Owner's Manual) is what you have to work with to do your charging.<br /><br />Your larger battery, if it is the typical Group 27 or so in size, has a total capacity of about 100 amp hours. I'm not even going to talk about the starting battery - you can figure out how it plays into your system for yourself - but it will have less amp hour capacity. As you run your electrical devices you deplete those amp hours at whatever rate your combined electrical devices devour them. By the time you have used up about 50 of the amp hours that are available the battery will be stone dead for all practicle purposes. Let's say that you run it down that far. If the battery is down to 50 amp hours and you have a charge rate of 25 amp hours from the alternator it should be pretty obvious that it will take 2 hours of running time to fully recharge it - if it were able to accept the charge at a 100% efficiency rate. I say that because you had 100 amp hours to start with, you used 50 of them up, and your replacement rate is 25 amps per hour - hence, 2 hours. In truth the alternator can not actually recharge quite that fast, but you are in luck. The rate at which the battery will accept a charge is not straight line. It will be most efficient at accepting a charge when the charging first begins and the efficiency will fall off as you approach fully charged. The last little bit takes a long time (for more reasons than simply the battery's ability to accept a charge, but we aren't going to go into that here much).<br /><br />Needless to say the condition of the battery plays a big part in how fast it will charge. New batterys with full electrolite that have been well maintined and have clean terminals and connections everywhere charge a lot more efficiently than batterys that are otherwise kept.<br /><br />So, what does that all mean? Well, the first thing it means is that it would be wise for your to get a handel on how much power reserve you have, need, and are working with. Needless to say keeping your batterys well maintained is essential.<br /><br />Let me make an example of what you might want to do as a mental exercise that will keep you out of trouble. I'm going to use my boat as an example just to show you how this simple calculation works and how you then apply it to your situation. I'll use mine because I generally know the numbers and also because its sort of an extreme case for a small boat.<br /><br />First off I have two wet-cell Group 29 hybrid Deep-Cycle/Starting batterys, they are identical and they have 135 amp hour capacities. My alternator (Suzuki DT-225) puts out about 25 amps. Only one of the batterys will be in use at any time. ABSOLUTLY NEVER RUN A BATTERY SWITCH ON THE BOTH POSTION unless you have your towing insurance paid up to date.<br /><br />Just for the sake of this exercise you should assume that every electrical device that you could reasonable be using was going to be used. You want to describe the worst case situation if you don't want to be stranded with a dead battery.<br /><br />What you need to do is list all of your equipment, its power draw, and how long out of any given hour you will be using it. Then add up the total use and see how that compares to your battery's capacity. Here's how/<br /><br />Equipment that would be running:<br /><br />VHF Radio 1 ........ 2.0 amp hours<br />VHF Radio 2 ........ 0.5 amp hours<br />Cell Amplifier ..... 0.5 amp hours<br />Fish Finder ........ 1.5 amp hours<br />Chartplotter ....... 1.0 amp hours<br />Backup GPS ......... 0.1 amp hours<br />Radar .............. 2.5 amp hours<br />Anchor light ....... 2.0 amp hours<br />Cockpit lights ..... 2.0 amp hours<br />Washdown Pump ...... 3.0 amp hours<br />Fresh Water Pump ... 1.0 amp hours<br />AM/FM/CD ........... 2.0 amp hours<br />Total .............. 18.1 amp hours<br /><br />So if you add that all up you can see that I use about 18.1 amp hours of current from my 135 amp hour total. What is the effect of draining that much out of a battery that size?<br /><br />First let me give your some rough numbers for estimating the state of charge of your battery. Listed below is the approximate voltage and specific gravity of a standard wet cell battery at various states of discharge:<br /><br />12.65+ volts = 100% charged (SG=1.265+)<br />12.45 volts = 75% charged (SG=1.225)<br />12.24 volts = 50% charged (SG=1.190)<br />12.06 volts = 25% charged (SG=1.155)<br />11.89 volts = its too late.<br /><br />So, if I take my 135 amp hour battery and drain it by 18.1 volts it will, in a perfect world, have been discharged 13.4% (1-(18.1/135)) or have a remaining charge of 86.6%, which would give it something greater than 12.45 volts (the voltage I would have left at 75%) left but less than the full charge of 12.65+. That would be plenty to start my engine However if I were to just sit there for let's say 3 hours with all that stuff running then I would have used about 54.3 amp hours of juice and that would have left my batterys at about 60% of their capacity(1-(54.3/135)). At 60% of charge I would have a bit more than 12.24 volts left to crank the engine, which would probably start it OK because I keep my engine well tuned, but for some guys it would be the kiss of death.<br /><br />Now you and I both know that what I presented was sort of an absurd case, but it should give you an idea of how to simply calculate what your power draw is and then compare it to the reserve of power stored in your batterys. For the recharge rate its just a matter of seeing what your alternator puts out and comparing it to how much power you estimate you have used up. <br /><br />Its not a bad rainy-day execise. I say that because once you have done it the knowledge sort of sticks with you when you are out on the boat and tends to make most guys a bit more prudent with how they suck down electrons. Sometimes it makes a lot of sense to shut off that tape player or the radar, maybe give those cockpit lights a rest, or fire up the engine when you start to think it might be about time.<br /><br />Oh, one last thing, and this is just a safety margin sort of thinking exercise. I said that I discharge batterys at 18-point-something and that is true, and I told you that I recharge at 25 amps per hour, which is also true, but if I was out there doing this stuff in my head I'd assume that I had to run the engine as long as I had discharged the batterys in ordrer to fully recharge them, just beause that 25 amp output is not getting into the batterys with 100% efficiency, so in reality I can expect the batterys to accept power a almost the same rate as I use them.<br /><br />Did I make any sense with this? If not I'd be happy to talk about it. I'm also happy to be corrected on my thinking on this one. Lots of guys know more than I do about this, I'm just an interested amateur. Remember, I estimated most of these numbers (not the voltage and Specific Gravity numbers, those are solid) and guessed at some of the equipment draw rates, but they shouldn't be too far off. You can look in any of the major catalogs or owner's manuals to get your actual power consumption figures.<br /><br />Thom<br /><br />On Edit: Typos
mattttt25
"ABSOLUTLY NEVER RUN A BATTERY SWITCH ON THE BOTH POSTION unless you have your towing insurance paid up to date."<br /><br />thom- i run my boat in the both position. when it get to anchor and turn off the engine, i switch to position 1. before i start the engine again, i switch back to both and head home.<br /><br />is there a problem with this, except forgetting to switch and running dead while i'm on the hook?
ThomWV
Let me ask you this. Why do you do it that way? What do you think you are accomplishing? Tell me how your day starts, is it with two batterys? Are the batterys the same or are you one of those guys who uses a "Starting" and a "House" battery? How well charged are the batterys when you start, low, good, fully charged? Now this, how do you know that your alternator is putting out power, do you have a warning light, does it work?<br /><br />I'd like to see you think your way thought what you've got before I start spouting what is my opnion only about what make sense and why.<br /><br />Thom
ThomWV
OK, back to the discussion. I will answer your question "thom- i run my boat in the both position. when it get to anchor and turn off the engine, i switch to position 1. before i start the engine again, i switch back to both and head home." in the last paragraph - so if you want to avoid my long-winded nonsense you can jump to the bottom. It might be the smart thing to do just for your sanity.<br /><br /><br />First lets think about what sort of boat we are talking about here, because it matters. I am not talking about a cruising sailboat with its solar array and days on end of rationed power consumption (the guys and gals who do that sort of thing tend to pay tremendous attention to the cataloging of power use that I described above) and minimal engine running for recharging. I'm not talking about the guy with a bass boat and a half a dozen battery and configurations of chargers to run trolling motors and such. I'm not talking about large house boats or the mega yacht Sportfishermen with their Killowatt generators. What I'm talking about here is the common day boat, maybe used for fishing, maybe for sking, maybe just for family cruises. Now and then it gets used for over night fishing or partying, mostly its a nice weekend boat. It might be on a trailer or it might be in the water much of the time, but its not a large boat, probably less than 28 feet or so. This is my boat, it is the boat I'm talking about, its probably the boat most of us have.<br /><br />OK, that's the background. Now, what is a perfect world for that boat?<br /><br />Well, it will have a battery who's size is such that it can start the engine. That is the most important thing it can do. Next it will act as a reserviour to store and release power when your ability to recharge is less than your demand for electricity. Of course you have to replace what you use in the recharging process but with our day boat, with everything working as it should, that is rarely a problem as long as the battery that we use is of large enough capacity in the first place. I'm going to get back to capacitys in a bit but for now keep that size question in mind. <br /><br />Now, what happens with such a boat on a perect day? Well, you start the day with a battery that is at 100% of its possible charge. Now no used battery has its full capability forever but go ahead and assume it does. When you start the engine it draws down some of that 100% power but in truth its very little. Everyone talkes about the demands of starting their engine as if it required a lightening strike. Even with todays high pressure injection systems it still doesn't take all that much to start an engine, a lot of amps in a hurry and good strong voltage but in truth you don't crank an engine more than for a few seconds (you do keep your engine tuned don't you?) and the power that is used in that startig process is replaced by the engine's alternator within mere minutes.<br /><br />So, you start the engine and get under way. Within a few minutes the power removed to start the engine has been replaced. You've got some equipment running but that's OK because the alternator's output is great enough that it not only recharges the little bit you took out of the battery but it also runs the engine and the electronic device you've got pumping back there. Now you stop to fish for a couple of hours or to watch the kidds splash around back by the swim platform while the CD player tells the world just what your taste in music is like. This is using up battery power, as discussed above, but the capacity of your battery is great enough that the depletion is not great compared to the reserve available. So the voltage at the battery doesn't drop much (look at the voltage numbers I gave you above for different states of discharge) because of your couple of hours of sitting and enjoying the boat. Now you decide to call it a day. You hit the key and because all is well with your connections and your battery and your engine it starts right up. Immediately the voltage regulation part of your charging systems notices that the power supply is low and it starts charging away. Depending on how much power you used, what the output of your alternator is, and how long you run the engine, it will, with luck, be fully charged by the time you return to the dock or trailer. This is a perfect world.<br /><br />Now, lets put a damper in our perfect world, let's 'make it real'. Let's say that you are a worry-wart and are constantly afraid of being stranded out on the water because of a dead battery. Maybe you did the arithmatic and felt that you were using a little more of the battery's power than you could replace with your run out and back or maybe you just don't trust your old battery or charging system. What would be the simplest thing you could do to avoid that stranding you are concerned about?<br /><br />Well, that's an easy one. Just bring alone a spare, and fully charged battery. Put it up in the cabin or under a seat somewhere and leave it alone. If you need it you can drag it out, hook up the jumpers and be on your way. I know guys who actually take the battery out of their tow vehicle and toss it in the boat for just this reason. It works.<br /><br />What are the advantages to doing this spare battery trick? The answer should be obvious. The advantage is that no matter what you have a good battery to do the most important thing, get that engine started and get you back home. The integrity of that batter has not been placed in peril because its not hooked up to anything. What I'm saying is that the spare battery under the seat, presuming it was good and fully charged when you tossed it into the boat, will stay fully chared no matter how terrible the corrosion on your other battery's terminals, no matter if your alternator has given up the ghost or not, no matter what, its going to stay a good battery ready to get you home.<br /><br />Now lets look at a boat with the best wireing system, one in which two idential batterys are wired into a standard multip point battery swithc in which you may select one or the other batter, select the use of both batterys at once, or turn off the supply of power completely (which is a safety measure to avoid fire that EVERY BOAT NEEDS) to the electrical system. <br /><br />With the 2-battery system you can run the boat off of either battery independently or you may use them in combination. <br /><br />If you use them in combiation the voltage available to the system will be roughly the average of the voltages of each battery (not exactly but I'm not about to go into that here) and the amperage that is available to the system will be the sum of the amperages of both batterys. What I mean by that is if you have one battery who's age and state of charge gives it 12.3 volts and 95 amp hours of capacity available and the other (lets say its the same battery but a year newer) had 12.5 volts and 105 amp hours capacity left. So you put the switch in the BOTH position and now you have about 12.4 volts available (the average of 12.3 and 12.5) and the total amperage available to you is 200 amp hours, the combination of 95 out of one battery and 105 out of the other). There is nothing at all wrong with this - not one blessed thing. However you need to understand something here. What you have just done is make those two smaller batterys into one larger battery with the flip of a switch. Where is your spare? What is your equivelent to the one tossed under the seat? You don't have one. So, now what is the effect if for some reason your alternator crapped out on you? Well, back it up. First off the power you used when you started the engine wasn't replaced while you were running. Next the power you used when you stopped had no way to be replaced. After a day on the water, CD player or baitwell pump doing its thing, will there be enough power left in either battery, or even in both of them combined to restart the engine? Maybe. Usually actually. So you bring it back to the dock or trailer and you clean up the boat, but this time when you got back the batterys were not fully recharged from the alternator on the ride back. Now you have a boat sitting there with two batterys that are both partially discharged. <br /><br />Let me digress for a moment. Battery maintainence, or battery killers if you want to call it that. 1. The single worst thing you can do to a wet cell battery is leave it sit with low electrolite. 2. Next would be to leave it in a state of partial discharge, which would be accomplished by undercharging it or not charging it at all. 3. After that you can kill one very quickly by over charging one. 4. Heat is a battery killer too and is to be avoided. <br /><br />Now back to the boat that just came back with partially discharged batterys - 2 of them because someone felt it was a good idea to have that switch in the Both position at some time or another. Here we have a boat that has partially discharged batterys that are going to be left to sit for some time. See item 2, above. So the next time you go out on the water if you are lucky, or is that unlucky, it will start OK at the dock, might crank a little slow, you might notice or might not, but it will probably start and get you out there. Will it restart the engine after a couple of hours of Stevie Ray Vaughn? It might this time but it sure isn't going to the next time. Starting to see what I mean? Most battery failures don't take place the day the boat dies. Most of them started a trip or two before. What is really a shame is that between trips the battery, which were left in a partial state of discharge, are steadly going down hill (see item 2 again).<br /><br />So, tell me if this makes more sense. Remember, I start with good batterys. Today is the 22nd of August, I think. That is an even numbered day of the month. So I've decided that on days that I believe are even numbered I'll run my boat on battery 2. If I had thought today was the 21st I'd have run it on battery 1. I go out and start the engine, which my combined Starting/Deep-cycle has plenty of power to do, and then I got though my Perfect Day sequency that we started with. I have never put the switch in "Both" so if there is something wrong with my charging system, cables, terminals, or even with the battey itself I still have my second, fully charged battery that hasn't been touched by anything, still standing ready in reserve just as surely as the guy who took the battery out of his truck. The only difference between him and me is I don't have to break out the jumper cables, I can put mine into the system by simply flipping a lever on the switch.<br /><br />Is this starting to make sense? How about this, because I was only discharging my one battery when my system had a defect in it somewhere I will know a lot sooner that something is wrong because my engine may not start, which is OK because I still have my reserve battery. It will get me home and allow me to deal with the problem.<br /><br />OK, I said I'd get back to your question so here goes:<br /><br />"thom- i run my boat in the both position. when it get to anchor and turn off the engine, i switch to position 1. before i start the engine again, i switch back to both and head home."<br /><br />How do you know that when you ran out there your batterys were being recharged at all? You don't. So if they weren't charging you have arrived at your fishing spot with two batterys that are now in worse shape than when you left the dock. You then flip over to one or the other of the two, which you are now surely going to kill if they are already discharged and you are placing your hopes on the notion that you haven't discharged got the other battery discharged to a point where it won't start the engine either. This would not have been the case if you had run out one one battery and just left the switch on that position. Had you done that you would still have a second fresh battery ready available to get you home when you found out your first battery had gone dead.<br /><br />That dear friend is the reason you NEVER run the boat on the Both position. There is absolutly no reason to. You do not need to recharge both batterys if you only discharged one of them when you initially started the engine or when you subsequently use the battery to power our stuff while you were enjoying the boat. Your spare battery is in just as good a condition as when you left the dock. Alternate the battery you use by whatever scheme you choose and you'll be much better off.<br /><br />Whoops! This isn't the end. I forgot that I had promissed a fellow that I would mention something else here. Stick around if you like, it may be interesting to you.<br /><br />Let's go back to the "Both" position and look at charging for a moment. Remember that I said that in that position what you had effectively done was average one big battery out of two smaller ones? Well that's not exactly true. What you have done is average the power availabiltiy from two batterys into one. However the batterys themselves, although now wired together via the switch, act as one only from the power of view of how much power they can supply to the system. This does not mean that they will act as as concerns the ability of each of them, individually, to recharge.<br /><br />No two batterys in any boat have exactly the same output voltage nor the same capacity even if you bought them in the same place on the same day. It doesn't matter if you installed them at the same time, if they were in the same storage area (heat and moisture considerations), maintained the same way, or even discharged and rechared at the same time. There will always be some differences. Not only that but the differences will become greater over time.<br /><br />Now, think about this. Your power regulation system really only 'knows' one thing about your batterys. That is the system, inessense, measures voltage. If it senses that you have high voltage, because your battery is good, it puts out less power. If it senses low voltage it puts out more power until the voltage comes up at which time it then decreases its rate of charge. Now in truth, before someone comes in here and calls me a mindless idiot (people will do that to you on the Internet even if they don't know a damned thing about you), what the regulator senses is not actually the voltage but the resistance to voltage, but I'm going to gloss over that because it really doesn't matter.<br /><br />Go back to my numbers for the two batterys, the one that had 12.3 (95 amps available) and the one that had 12.5 (105 amps available) volts. Remember that as far as the charging systme is concerened its just dealing with one battery, but that the battery it thinks is on the end of the wire is not a 12.3 or a 12.5 battery, its a 12.4 battery. What does that tell you? Simple, that it is overcharging one battery and undercharging the other. Go back up the page a bit and see what the 2nd and 3rd worse things you can do to a battery are. You are doing them both whenever you run a battery switch in the "Both" position.<br /><br />OK, fingers are tired now. Time to quit for a bit. <br /><br />Let me say this - its is important. I am not an engineer, not by a very very long shot. There are thousands of guys around who know more about this than I do. I have fond out what I could and found what I have found out to seem to prove true. That does not mean that what I have told you is the gosphel of boat electroncis. Look around, ask around, see if you can find better information. More importantly do what I asked you to last night. Think! Think about your system and what is really going on. Think about the alternatives and think about your comfort level with you own understanding of the system. Then act in the way that makes the most sense to you - don't necessairly listen to me.<br /><br />Ready for questions.<br /><br />Thom
mattttt25
edit...<br /><br />thom- i have a very simple set-up. i run a 20' center console, 150hp outboard, vhf, am/fm radio, gps, fishfinder, lights, and bilge pump. i have 2 identical starting/deep cycle combo batteries purchased before this season. they are hooked up to a perko 1-all-2-off switch.<br /><br />the boat sits at a pier all the time. i keep my switch set to position 1 to serve the bilge pump if needed. before i turn on the engine, i switch to the both position. i had assumed this would allow me to fully charge both batteries as i ran the boat. when i turned off the engine, i would swicth back to battery 1 and keep 2 as my backup.<br /><br />i appreciate your time and all the info you provided. it makes sense to me now. i plan to start alternating which battery i leave on while the boat sits at the dock. i will then use that battery to start the engine and run with only that battery on. when i return from the day, i will switch batteries.
Turn-key
Thanks Thom,<br /><br />For such an intelligent and well explained answer. I now have a much better understanding of the whole electrical/battery/recharge system in a boat.<br /><br />Regards,
gsbodine
Originally posted by ThomWV:<br />Ready for questions.<br />
I must be a masochist; I love reading these things. I guess it's because it's the area I know least about. Anyway, since you're ready, I'm going to ask one. <br /><br />Actually, I saw that W...250r asked something similar the other day. If the batteries are wired up in parallel with the switch on both and charging, how does one get overcharged and one under-? Wouldn't voltage flow (ok, so I'm a total n00b at this) in such a way as to make both batteries essentially the same amount discharged until they're both charged? <br /><br />I only ask this out of curiosity; I don't disagree with anything you've stated. I appreciate the experience you share.<br /><br />Thanks.
ThomWV
Thanks guys.<br /><br />Matt. Let me suggest this to you, and its another of those things you should think through for yourself.<br /><br />If you have to have your battery switch turned to one or the other battery to have your bilge pump's automatic circuit operate you may want to consider moving one wire to change how that works.<br /><br />As it is now you must have the wire that goes from the battery switch to bilge pump's float switch connected to the common (output) terminal on the back of the battery switch. That is OK and it gives you the situtation that you described, where the switch has to be either in the 1, 2, or Both positon for the pump to work. As you note though it means that you must have the switch turned on for the pump to work. If you move that wire from the common (output) lug to either of the other two lugs it will allow the pump to work, if it needs to, even if the switch is turned off. This is nice because if you can leave the switch turned off it reduces the exposure of your battery to discharge by other gremlins that might be hiding in your boat's electrical system.<br /><br />Of couse on the down side is that if your float switch sticks or gets junk under it the pump will begin to run and will continue running until the battery dies. So there is an up side and a down side.<br /><br />I will tell you that in my boat there are two bilge pumps and I have them wired with the power supply going directly to each of the input lugs on the battery switch. One pump for each battery. That way I can keep my battery switch turned off but if something were to happen (my boat is trailer kept) to clog up the drain the pumps would still be avialable to pump out water if the need be.<br /><br />Oh, and I might as well add this too. I use an onboard charger, and I recommend them to everyone. I do not have my charger leads connected directly to my batterys. I run my charger leads to my battery switch input terminals. There is some loss of power available to charge my batterys because of the additonal length the current has to travel down the battery cables but they are large so I doubt that the loss is significant.<br /><br />Oh, and I should have said this too, but you need to just see how your boat use fits into a sensible plan. Sometimes it makes sense to run out to the fishing or playing grounds on one battery and then switch to the other battery for the ride home, you know, to sort of ballance the use time between batterys. Once again, not in the Both position, but one or the other. Actually the only time you should go to Both is in an energency start situtation, where neither battery alone will get you started but in combination they will. Remember, it takes a lot more power to start an engine than it does to just keep one running.<br /><br />Thom
18rabbit
Masochist (previously known as Ol’ Norse) - I wasn't asked but maybe this will help until Thom gets a chance to respond: essentially, yes, you are correct. Something that has been omitted from this (and the other thread) is any consideration for ‘resistance’. It matters and will affect the way the batteries charge/discharge.<br /><br />Two batteries with dissimilar voltage will rapidly equalize when the battery switch is flipped to “Both”. As the voltage of a battery drops, the batteries ability to accept a charge rises due to a declining resistance. A battery at 11.7v in parallel with one at 12.5v can both be charged from a single charging source (alternator, inverter, solar panels, etc) with the switch set to “Both” without harm to either battery.<br /><br />When batteries equalize, the process starts out as a very rapid transfer of potential. As the donor battery’s voltage drops its ability to ‘push’ potential into the recipient battery also drops. At the same time, as the recipient battery’s voltage rises the ability to accept potential is dropping. The equalization process starts off very rapid and slows as the batteries’ voltages begin to align.<br /><br />With the battery switch in the “Both” position you can think of the charging source as a third battery with unlimited potential and the whole lot is equalizing. It doesn’t matter if the charging source is applied to one battery, the common lug on the switch, or bridged between the two batteries. The battery with the lowest voltage will get the lion’s share from the highest voltage (charging source) while the other battery will resist accepting a charge until the lower voltage battery catches up. When the batteries’ voltages become similar, charging will be (theoretically) equally applied to both batteries.<br /><br />If there is any interest I can explain the idea of bridging two batteries in parallel with a charging source applied to the positive post of one battery and the negative post of the other, as opposed to applying the charging source to a single battery…but I’m thinking you can figure it out based on the paragraph above … how batteries equalize … the process slows as the voltage becomes similar … that kind of thing. :) <br /><br />Someone asked the question how you know your battery is being charged when you are underway. Voltmeter. You can use anything from a $25 analog in-dash to a $125 digital voltmeter with high and low voltage alarms, etc. Add an el-cheapo toggle switch and you can monitor the voltage of either battery. Cool thing about the inexpensive analog meter (and toggle switch) is with identical batteries you can flip between Battery 1 and Battery 2 and have a graphic indication of where your voltage will be if you (a) equalize the two batteries, or (b) when you kick over the motor and start charging the batteries in parallel. With a digital voltmeter you have to think numbers and figure it out.
ron7000
Banned
it was mentioned that if you run the battery switch in the both position how do you know the good battery (and the other) is being charged.<br /><br />Are we talking strictly about outboards?<br />Is there a volt guage?<br /><br />One thing I don't think was mentioned was if you connect 2 batteries in parallel, with no diode or no isolator, the stronger battery will flow into the weaker battery until they balance out. If the switch is on both and motor is charging, then both batteries will get an equal charge. The bad thing is if one battery is bad, it will pull from the good battery. And if it were dead and you try to start the motor on the both position, you wouldn't have enough power because all the juice would go from the good batt to the bad batt and not to the starter. In this case, you start the motor in the single batt. position, then once running switch to the both position to charge both batteries... just have to make sure you run long enough otherwise you will end up leaving the good battery less than 100%.
mattttt25
oh boy, so maybe my original procedure was not that bad, just a better one provided by thom?<br /><br />and did ron just give bad advice on switching to both when the engine is running? i thought you did not want to switch those things when the engine was running and that it stated it on the switch itself...
