nola mike
- Apr 22, 2009
- 5,777
You'll have to be a bit more specific, but the wire from the choke to the coil should be a resistor wire that will get hot. You'll get less than 12v to the coil exterior when cranking. Looks like a tan wire from the solenoid supplies the full 12v only when cranking. The wiring looks a bit different than the typical gm wiring, so can't comment on the ignition switch (though you should have 12v there). You should also have 12v at the choke itself.
