trolling motor upgrade question
Vlad D Impeller
I'm replacing an old motorguide 28 lbs thrust motor with a new Minn Kota 40lbs thrust motor.<br />Is just a matter of me installing the new motor and plug it into the old recepticle and go? or is there more to do? :confused:
roscoe
Re: trolling motor upgrade question
If the plug fits, use it. If not, you may need an adapter plug or a new recepticle.
Silvertip
The 40# motor will draw more current at high speed than the 28# so the existing circuit breaker (if you have one) may not be up to the task and may have to be changed for one with a higher rating.
