Got a Sub-Troll 900 today and instructins make a big deal out of connecting the black lead back to "both the boat's ground system and the Negative battery terminal...the electrical current must be returned back to a water ground to complete the circuit". <br />Practically speaking, if I hook it back to the Negative terminal of my main boat battery (with engine and instruments running off it) will that be OK? <br />The instructions go on to say "normally the water ground is obtained via the engine...which is common to the negative battery terminal."
