I can't track this
POINTER94
I had a switch go bad on my anchor/navigation lights. When I replaced it I can't make the white top light come on. <br /><br />discription: Two red hot lines. One tan line that splits into two lines. One white line I believe goes to the red/green which is now working and one black ground.<br /><br />The switch. It has eight spades to connect to, and I currently have power to the masthead light connections and the bulbs look and pass continuity on multi-meter. But no light? I am of course looking at the ground issue, but the red/green is working fine?<br /><br />Confused, any ideas or suggestions. I have manipulated the leads in every way possible to make it work. It is just being stubborn. Help!
POINTER94
Re: I can't track this
Ralph,<br /><br />Swing and a home run. Figure 15 is what I have. I am assuming that the "+" designation is where I have to run the two red hot lines.<br /><br />Pardon my ignorance but I am just too lazy rip up the dash as it has been 95 degrees out the past two weeks and I haven't had ac in that time. Whine over. <br /><br />thanks, dk
