Re: Length of pole holding stern white light
Sidelights (red & green) are required
when underway between sunset and sunrise so yes, if you are anchored, the sidelights
should be off. When anchored you should display an all around white light. Normally on some boats this would simply be the stern light if it can be seen in an unbroken 360 degree arc. If the stern light cannot be seen 'all around' then it should be the masthead light (many masthead lights have a second bulb built-in so they can function as the all around light when not underway). Many boats only have sidelights and an all around light affixed up high on the hard top or protruding above the bimini as allowed by the regulations for vessels less than 12 meters.<br /><br />Most all around pole lights seem to use a 10 watt bulb drawing 0.83 amp, so your 70 A-H battery theoretically should last over 70 hours with just the all around light on. The all around anchor light won't drain your battery overnight (unless you're in antarctica where the nights are 6 months long
), but be sure to take into account the other stuff like the stereo, cabin/cockpit lights, etc. Having two batteries is a good idea - use one for this kind of stuff, save the other for starting the engine the next morning. If you have a battery switch, once you start the engine you can switch over to charge the house battery if you like.<br /><br />Be safe, have fun!
