I have a 1990 3.9 Mercruiser that the temp gauge barely reads above 120. Grounded the sending wire and gauge moves accordingly. Thought maybe problem with thermostat or temp sending unit. Both seem to test okay. I checked the tan sending wire at the temp sensor. I was getting about 9.5V. Shouldn't I see 12V going to the sensor? I Have 12V at the ign terminal on the gauge. I checked the ground at my gauges and it shows perfect continuity, however when I turn the ignition switch to run the ground shows a reading of 25 ohms. Is this normal?
